MSD Solid State Relay Box Opinions
wesinls
Anyone using them?  One obvious disadvantage is if a portion of it fails the whole box needs to be replaced - but is that likely?  Sure simplifies wiring.
Haven't used this product, but others and found them very reliable.
Several guys in our group are running Leash relay boxes. The Leash is pretty versatile and I like the set-up. Can't comment on the MSD stuff cause I have no experience with them.
I use SSRs for work.  While not specifically this model, we very rarely have them fail.
Great thing is you can use it with a PWM controller for your existing brushed fans to cut down on cycling/current draw and maintain a more even temperature.
I have used them on a few cars, and as @Rockwood said they are great for controlled  PWM  devices (I use these with the Holley ECU), but what I like is that if one does fail as long as you put a service loop (and battery cutoff switch)  in the wiring you can jump the SSR if needed
I wonder if you can use it with the Holley or other engine management to cut out a fuel pressure regulator as well...? Ford's been doing this for years with their returnless fuel pump setups: no fuel pressure regulator, just use the fuel pressure sensor to control fuel pump output in real time.  Especially useful if you have a monster pump and are just pumping it through the regulator constantly heating it.
I use the Leash relays and boxes on some cars because they have 70amp SEALED relays and have a fuse, super convenient for an add-on situation.. also their fuse boxes are self contained with 70 amp relays  and fuses ands have a LED that indicates a bad fuse
The downsize is a failed relay can only be replaced by Leash  (or you can desolder yourself of course)
BUT, the whole thing is only like $25.
Single 70 amp relay module. Has heavy duty 70 amp industrial relay. Uses heavy duty J-case/FMX fuses (NOT INCLUDED).
That's why I ninja-edited it to say "with the fuse at least"...  LOL
Neither of them come with the fuse.
