Sand Shark
- 5,384
Looks like he tied those into the frame. On the stock cage those down tubes end in the bed and do not attach to the frame.It looks like they did something here View attachment 81103
Looking forward to some first hand reviews and knowledge on this car.Been tearing into the maverick R since picking it up last night to see what I can upgrade before glamis. If you’re selling off another Sxs to get one of these, hang onto your aftermarket seats. They drop right in and use the same frame rail and slider as the X3we know those are a joy once dirt gets into them
If you want to do some welding S3 Powersports has a really nice weld on gusset kit for the lower arms. CalTech has a much simpler one.Been tearing into the maverick R since picking it up last night to see what I can upgrade before glamis. If you’re selling off another Sxs to get one of these, hang onto your aftermarket seats. They drop right in and use the same frame rail and slider as the X3we know those are a joy once dirt gets into them
Always a good idea to check the suspension bolts. The assembly line misses stuff. It is interesting they went with ball joint type end for that radius rod.11 minutes ago, Rockwood said:
It's technically no different than a front tie rod in function/purpose.Always a good idea to check the suspension bolts. The assembly line misses stuff. It is interesting they went with ball joint type end for that radius rod.
Did not think of that way, but makes perfect sense.It's technically no different than a front tie rod in function/purpose.
None of these guys seemed really impressed. If I was a can am guy, I think I would just be happy with my X3 and save the money. Kind of bummed after this video. I was expecting more. That chatter did not look fun. My Wildcat XX doesn’t even notice those.1 hour ago, Rockwood said:
Yep, they didn’t seem to like it much. Who knows how much air they were running, and I have a feeling Sport+ made the chatter worse. :dunno:None of these guys seemed really impressed. If I was a can am guy, I think I would just be happy with my X3 and save the money. Kind of bummed after this video. I was expecting more. That chatter did not look fun. My Wildcat XX doesn’t even notice those.
They did mention the Pro R a lot, but then again it’s the primary competitor. They kept complaining about the weight and how big it was, but it’s not like the Pro R is a featherweight.Also consider this, they were not invited to the pre-ride event and I have read a couple places that they are now sponsored by Polaris.
Yeah, and they did say it was meant more for open desert. I notice that the SxSs in our group can zip through the small dunes better than the buggies (even mine which is lighter than any current SxS), but when it comes to medium and large dunes, no contest.The important take away from the that video is they did not break it. They aired it out pretty good and it took some good hits with those lower arms. Those guys usually break something.
SXSs are fun in the small dunes.Yeah, and they did say it was meant more for open desert. I notice that the SxSs in our group can zip through the small dunes better than the buggies (even mine which is lighter than any current SxS), but when it comes to medium and large dunes, no contest.
People were posting about tire rub issues, it's clearly has small room for wheel bulging...I'm curious what paddles will work without using offset wheels or even a wheel spacer.16 hours ago, Azdunerat said:
Slightly rubbing but causing no visible wear? Meh. Paint everything black and you’ll never know. :biggrin:People were posting about tire rub issues, it's clearly has small room for wheel bulging...I'm curious what paddles will work without using offset wheels or even a wheel spacer.
