Rockwood
- 8,566
Ah, yeah. LOLBut if I took the Starlink dish on an RV trip, all the Wifi stuff at the house would shutdown, until I brought it back. Correct?
You can port the old Cox phone number to a cell, or even a forwarding service that goes to an existing cell. I still keep my Spectrum internet service at home, using starlink as a fallback when at home, and then my main access when away, with cell being the fall back. It works great, is worth the money, but does still have slowdowns in "busy" areas. There is only one ground station serving the glamis area, so Im sure it will get bogged down as more roadrunner estate folks catch on.But if I took the Starlink dish on an RV trip, all the Wifi stuff at the house would shutdown, until I brought it back. Correct?
They still limit the number of users in geo areas, even with the roam feature. If you have a vacation home, or address outside of most urban areas, you can use that as the order address and most likely will be able to get going right away. You can then change your billing address back to your main home. Starlink did this because folks in those black out areas were ordering the RV (roam) service, but never leaving the urban area. This is also why roam can be limited/throttled when used in urban areas.We're trying to purchase the SL roam and it won't let us purchase is anyone else having this problem
X2 on this. Im ordering one and I’d like to mount it to my Moho roof with one of the flat mounts. Curious on how well or not well it does.Can anybody confirm that these flat "Star Mount" enclosures work well? I know the stock dish moves itself to aim, so not sure what you give up by having a fixed flat mount. I assume there must be a reason they went through the trouble to make the auto aiming base for the dish.
I make the plastic enclosures for this guy STAR-MOUNT Systems: Mounting Solutions for Starlink Satellite Internet – Star Mount SystemsCan anybody confirm that these flat "Star Mount" enclosures work well? I know the stock dish moves itself to aim, so not sure what you give up by having a fixed flat mount. I assume there must be a reason they went through the trouble to make the auto aiming base for the dish.
