Badbar88
- May 7, 2021
- 71
- 52
What are the pros and cons of having a VW style outer pivot point vs a dual bushing style? I get there is a bit of adjustment using a heim joint. Is there a strength or longevity benefit?
I have a car that's had negative camber from the start. It's using VW style outer pivots. I can't acheive 0° camber until I'm at full droop. I'm toying with the idea of mocking up some new trailing arms to correct this issue along with the fact that I developed some cracks from a hard bottom out.
I'm leaning toward changing things up to the dual pivot style because it seems like it would be much easier to get right.
