Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,589
- 2,849
Ah, the way I read all the posts above were about heating water.I meant with the heater. I don’t notice any difference in the shower.
I had to reread that as well, I thought we were all on the water heater.Ah, the way I read all the posts above were about heating water.
Still a bit confused. The air in the coach isn't mixed with the combustion process. A flame is heating a tube with air passing though it. How that tube is heated has no affect on the air in your coach. Unless there are leaks. Which would/could/may bring CO gasses in.I had to reread that as well, I thought we were all on the water heater.
How about some pictures for what you guys are talking about…
They are hydronic heaters, not air. You have a closed loop heated fluid that circulates around to local heat exchangers with small fans. The fans blow across the exchangers and heat the coach. The hot water system uses the same boiler but a secondary exchanger to heat the water.Still a bit confused. The air in the coach isn't mixed with the combustion process. A flame is heating a tube with air passing though it. How that tube is heated has no affect on the air in your coach. Unless there are leaks. Which would/could/may bring CO gasses in.
Sorry for the side bar In Excess...
OK. That really doesn't change my question. How does that make the air in the coach different from propane?They are hydronic heaters, not air. You have a closed loop heated fluid that circulates around to local heat exchangers with small fans. The fans blow across the exchangers and heat the coach. The hot water system uses the same boiler but a secondary exchanger to heat the water.
It doesn't. Just a different fuel and way of heating and distributing the heat. One big difference though is with propane it puts lots of moisture in the air. You know how you get lots of condensation on the inside of your windows when running your propane heat. You don't that with this systemOK. That really doesn't change my question. How does that make the air in the coach different from propane?
Toter went in production this week, completion in early July. My friend at factory will be taking pictures along the way.Of what year? Or are you talking only chassis delivery to Renegade? What is projected completion of the coach and delivery to you? Most of the Renegade custom line are being quoted year + currently I believe? Maybe the Sport Decks come much faster since the coach portion is easier?
We plan on using it a bit this year.I want one! Congrats. Use it immediately. The warranty will expire soon. Use it more the first year than you'll ever use it, Get the bugs out! They're in there. Drive it....Use it. Turn on Everything! You'll be glad that you did. Peace
