Fuel Filter questions
Greylynn
Oct 12, 2022
6
1
About to take off my fuel filters to check them out.  Car has a pre and post pump filters. Before I go digging into these. Anyone happen to recognize what brand they are? I don't see any markings on them. I'm wondering if they have reusable filters in them, or if they have a replaceable filter in them. How often do you guys service these? Thanks for the assistance in advance! I'll be changing the oil, and taking a look at these this weekend. Car is a Buckshot with a Turnkey LS2, and Kenny Bell charger.
Those will come apart and you can clean the internal screens. Kartek and or McKenzies will have these but like i mentioned you can service those and re-install / re-use.
Should be serviced every pre-season prep.
Ok, thanks, that what I was thinking. What micron are the pre and post filters usually?
Usually 100 before the pump 10 after the pump .
10 micron filters smaller particles than 100
This is accurate. The 100 micron pre-filter should be stainless mesh and you can clean it. The 10 micron post-filter should be paper and needs to be replaced. Those aren't Areomotive housings but they take the same Areomotive filter, around $20 at Kartek or Mckenzie's. Make sure you change the O ring too, the new filter will come with one.
If you're running E85 the 10 micron filter needs to be a Areomotive Glassmat filter. The paper comes apart with E85 engines.
And why I said Double Check me!  :dude:
Well I swapped them out today. They took the Aeromotive 12601 filters. O-Rings weren't the same size though, mine are way bigger, had to use the old ones. I'm going to try to find out what these filter bodies are, or I"ll have to size them and find some.
You put 10 micron filters in both housings? Pre filter should be 100 micron.
Your setup sounds really good with the Buckshot and Turnkey LS2 with the Kenny Bell charger. I am not sure about the brand of the filters if there are no markings. Some filters can be cleaned and reused. Others need new parts inside. The best way to know is to open them and check. I usually look at my fuel filters every few oil changes. I also check them if the car feels like it is not getting enough fuel. Good luck with your oil change and checking the filters this weekend. I hope it all goes well.
