Dockmaster
- 807
Here’s my stupid question; is there a difference between an S4 and an S4S ? Why do I see some calling them an S4 and some an S4S?
there is a s4s and a s4d the s4d had a bigger ring and pinion i believeHere’s my stupid question; is there a difference between an S4 and an S4S ? Why do I see some calling them an S4 and some an S4S?
Sean has a great write up in this thread explaining the difference between the S4 and S4D - you are correct, the R&P is bigger in the S4D. But I don’t see any trans listed with a designation of S4S. So still looking to answer the question; is there any difference between an S4 and an S4S or is this just people using different designations for the same trans?there is a s4s and a s4d the s4d had a bigger ring and pinion i believe
S4"S" is a somewhat of a legacy term that many builders use to differentiate the S4 and S4D. The extra S doesn't mean anything other than it's a 10" R&P trans.Sean has a great write up in this thread explaining the difference between the S4 and S4D - you are correct, the R&P is bigger in the S4D. But I don’t see any trans listed with a designation of S4S. So still looking to answer the question; is there any difference between an S4 and an S4S or is this just people using different designations for the same trans?
Thank you! Confirms my assumptions.S4"S" is a somewhat of a legacy term that many builders use to differentiate the S4 and S4D. The extra S doesn't mean anything other than it's a 10" R&P trans.
You would be surprised how many people think they have a sequential trans because the case says MD4S on the side.
Is there a remedy for this? my car has just recently started to have this issue. this PBS trans has all Weddle internals however not sure about the shift mechanism.Best to e-mail me for updated drawings. Can't load them here as they are PDF.
PBS was basically a copy of the Mendi S4/S5 with a few alterations to the shift system and housings, but they were still never 100% reliable with shifting and still have housings that crack/break. Most notable issues are bad shifting or "ghost" shifts, where the shift lever is pulled/pushed to upshift/downshift to the next gear, but the shift mechanism inside does not shift into the next gear (common problem with pre-Weddle Mendeola sequentials as well).
PBS is now defunct as of early 2020. Any specific PBS parts that are broken will not be able to be purchased new. Can use most of the internals to install into new Weddle housings for around $7000.
Notable difference is that the bottom of the PBS trans will hang down about 1" lower if you choose not to raise the engine.
Always best to call or e-mail me direct for timelines.
Shift mechanism parts are specific to PBS, and cannot be converted to Weddle parts.Is there a remedy for this? my car has just recently started to have this issue. this PBS trans has all Weddle internals however not sure about the shift mechanism.
Thanks for the reply Sean, do you know if the ghost shifting has a remedy? mine seams to get hung up in 2nd while the selector arm ends up in the 3rd and 4th plunge arm. I apologize for my lack of technical terms.Shift mechanism parts are specific to PBS, and cannot be converted to Weddle parts.
You need someone with enough patience to tune the springs so that the mechanism returns to center after every shift. This is a common problem with the Gen 1 Mendi shift mechanisms, which are the same as the PBS. It's a PITA, which is why I no longer take them in for service. The juice isn't worth the squeeze.Thanks for the reply Sean, do you know if the ghost shifting has a remedy? mine seams to get hung up in 2nd while the selector arm ends up in the 3rd and 4th plunge arm. I apologize for my lack of technical terms.
Thank you Sir, Ill give it a shot next time it happens.You need someone with enough patience to tune the springs so that the mechanism returns to center after every shift. This is a common problem with the Gen 1 Mendi shift mechanisms, which are the same as the PBS. It's a PITA, which is why I no longer take them in for service. The juice isn't worth the squeeze.
Easy fix is to lightly bump the shifter in the opposite direction of the shift you just performed, to help return the mechanism to center.
@Sean@WeddleI just had a 4E gone through including a new R/P. I was told that the next time I need to replace the R/P, I will have to convert the 4E to a 2D at an approximate cost of $9k because once the current inventory of gear sets runs out, there will be no more made. Is this true? should I buy one now and sit on it?
Im sure Sean will cover but if your in CA a VERY reputable builder in Fullerton advised its closer to $5000 to upgrade to a 2D. Didn't mention anything about the gearsets.@Sean@Weddle
Extremely happy to report that my problem was in the sloppy shift linkage. Another board member @Agricon was able to share his past experience and was spot on. after tightening up all linkage the car ran like a raped ape, and the trans never felt more solid. Obviously I will need to start planning for the upgrade but my family was thrilled to be back up and running and we will be able to close out the season. Thank you Sean@weddle for your help as well.You need someone with enough patience to tune the springs so that the mechanism returns to center after every shift. This is a common problem with the Gen 1 Mendi shift mechanisms, which are the same as the PBS. It's a PITA, which is why I no longer take them in for service. The juice isn't worth the squeeze.
If you use the PBS shifter, in a rear engine car, you have to loop the main cable at the trans so it pulls the shift lever from the rear for proper pull to upshift shifter movement.I know I have seen it somewhere before but i cant seen to find it now. Im getting ready to install a PBS in place of a 2D in a buddies car and couldnt remember which way the shifter cables are routed or i guess which way is an up shift and down shift on the shifter arm
@Sean@Weddle you would not recommend buying a car with a PBS at this time?Best to e-mail me for updated drawings. Can't load them here as they are PDF.
I wouldn't say that, they are still a decent trans to have. The unfortunate part comes when a housing cracks/breaks or a shifting components wears out/breaks. That could be a year, it could be 10 years.@Sean@Weddle you would not recommend buying a car with a PBS at this time?
