ChasingSand
- 885
In the market for new 235/85/16 for the toy hauler and wanted to see what everyone is using or buying these days?
Interesting, i always thought the 14ply trailer tires had better side wall stiffness for trailer sway. I get it the smaller tires for car hauler trailers would be ok, but for a fifth wheel would it be ok?Lt tires, trailer tires suck
Fill me in on this pro-rate your getting. I run the same tires and change them4-5 years in due to the cracking.Michelin XPS Ribs.
Have been running them since 2004.
They get ozone cracking every 4-5 years, Michelin always pro rates around 65% of the cost.
Need to double check the ply but the LT XPS RIBS are great.Do they make the LT Tires in a 14 Ply? Reason I ask is that the trailer is only a double axle but is 37 feet long. I need all the carrying capacity I can get.
The XPS Ribs are only rated at 3042 lbs each and 80 psi. This might be OK on a smaller fifth wheel. Personally, I would not run them on a large dual axle like you have. The Sailun S637 that I run (and probably any 14-ply trailer tire) is rated for 4409 lbs each and 110 psi. I used to run LT tires when I had a lighter trailer, but I wouldn't do it with my current one.Do they make the LT Tires in a 14 Ply? Reason I ask is that the trailer is only a double axle but is 37 feet long. I need all the carrying capacity I can get.
Discount tire has always helped me in making the call to Michelin etc.Fill me in on this pro-rate your getting. I run the same tires and change them4-5 years in due to the cracking.
Also remember if you go to 110psi tires, make sure your wheels are rated to that.
That’s what I’m using.Sailun S637. They have been bulletproof for me. Be aware, they are heavy 14-ply tires and are rated for 110 psi. They make them in 235/85-16 and 235/80-16.
Another vote for the Sailuns here. Made the switch a few years back on my triple axle fifth wheel and will never look back.Thanks everyone! Looks like I will be ordering the Sailun tires
