HTElectrical
- May 6, 2021
- 238
- 86
My last trip on the very last run at St. Anthony's my car just died about halfway thru the dunes. Waited a couple of minutes and it fired back up. Decided to head back to IDRV, and make it about 5 minutes or so, and it cuts out again. Rinse and repeat 3 more times and finally back at IDRV. Swapped out the fuel pump relay and that didn't help. Now I am not 100% sure that it is the fuel pump, but if it is, I wanted options for a new pump. I am currently running a Mallory Marine Electric Fuel Pumps 11106M. It was $229.95, and now they want $278.95. The pump (if it is the problem) did not even last a year.
I am using Aeromotive Filter, and filter. Fuel pressure is fine at 58 PSI, (at least when it is idling and revving while stationary.
I would appreciate suggestions on a DEPENDABLE external pump that doesn't break the bank.
Thanks in advance.
Thanks in advance.
