EastMT
- Jul 21, 2022
- 970
- 624
Someone mentioned increasing the rear tire pressure when the sand is wet for less bit. How high of a PSI would you go? 33” and beadlock if it makes a difference.
Thank you!I run a 33" tire as well, 10-13 psi while dry, depending on conditions, and when it's wet I'll typically run somewhere around 15-18. It definitely makes a difference. You will have to play with the pressure to find the sweet spot, basically, when the sand is wet add a little pressure and test drive, keep bumping the pressure up till the car doesn't bog and that's pretty much it.
It's going to be different for everyone, based on h.p. weight of car, driving style, wheel width, etc.
Also makes for great "bead lock by air pressure".17-18psi for me all the time, wet or dry.
Try to remove some stress on the drive train is what I do.
Not me. I went I-15 to L33 then one exit north on the 20. My rig stands out from everyone else here. Think somewhere in between Standford and son and Beverly hillbillies.Did you cruise through Saint Anthony on your way in, saw a toy hauler with Montana plates and a trailer hitch on the back?
Thanks. I didn’t consider the sidewall flex being affected by the temperature, good point.If I remember correctly St. Anthony sand is a little more coarse than Glamis sand so your car will float better to start with.
That being said I would do what others have suggested by starting at one point and then adjust the pressure.
One additional point is that the cold weather can affect how stiff the tire is, especially sidewall flex. So a little trial and error may be your best bet.
