Dzrtrat1111
- May 7, 2021
- 94
- 103
The is a continuation and end result of my last post “high idle hot start” I replaced the IAC with no change in hot start idle but said screw it, I’m going.
Came out to the dunes early Thursday morning and the wind was howling 40+. The sand was perfect Friday morning and went for a ride with my group. Within 10 minutes I noticed my car was running hotter than normal so stoped at the hill to check it out and found only one fan was working. Went to back to camp to chase the problem. My electrical guy is in my group and started chasing it. Found the fan and relay was good but an issue with the trigger wire. While working on the fix and the fuel pump stops working. Find the ECU, is now not triggering the fuel pump. So, we wire the pump to a switch to get me through the trip. Get that done and now no spark and the engine won’t start.
I’m thinking the ECU is toast, so here I sit enjoying the Sun and camping, thinking I should convert to a Holley.
for reference: LS 376/525 GM crate engine
CBM harness and Mefi 4b tuned by CBM.
** Also, the beginning of last season the ECU stopped triggering the fans, so I wired them to relays and push buttons breakers, controlled by a temp sender in the head and had no issues since**
