MWB
- May 3, 2021
- 3,036
- 3,066
So, I was having some trailer wiring issues or that is what my truck was telling me. All of a sudden, I would get trailer wiring fault, Trailer disconnected and no trailer brake. Jiggle the cord sometimes the wiring fault would stay on, but the brakes worked. The other day the trailer wiring fault stayed on after the trailer was disconnected.
Noticed that the plug that goes into the trailer connector was cracked. So made do best I could. Everything seemed ok. Pulled trailer out and disconnected and now I can't get it to see the trailer.
With the trailer plugged in I can get the flasher, running light all to work correctly but no brakes.
I have the correct pin that will go from 0 volts up to around 12 or so as I move the manual slider on my factory brake controller, when I do that, it says trailer disconnected and I have no brakes.
Any Ideas?
I found three 7.5 amp fuses on the Toung of the trailer and they all ohm out as good, any place else I should look for fuses for the brakes?
Any Ideas?
