UTV tires on a Sandrail???
Stinky
I'm working on "The Animal" (name by the PO's dad who is now gone...).  It has a SA w/bus reduction gears and it will have a Nissan 2.4 Z24 motor (100-125HP).
Is is a street-legal  pan-framed desert buggy.  I plan on going to the dunes with it, once or 2x a year.  I would expect the weight to be below 1,500#.
I just stumbled on to this.  The one tire has a rating of just over 1,000#, per tire.  They have multiple sizes.  These are significantly cheaper than a "real" paddle...about $200 on Summit.... $10 Oversize Shipping.
https://system3offroad.com/ss360-snow
https://www.summitracing.com/parts/s3o-s3-0680?rrec=true#overview
I did not find any ratings for these.
https://www.proarmor.com/en-us/shop/accessories/tires-wheels/tires/sand-rear-tire-32x15x15/
Thoughts?
there's really no reason it would not work
only two real issues that come to mind overall buggy weight (most SxSs are 1500-2000lbs) and the paddle cut may be short but with SxSs in the 100-200hp range you are still right in the mix with both
another thing is most sxs tires are for a 8 maybe 10" wide wheel.  Not sure how they would fit on a buggy 12" wide wheel.
Really just boils down to the sand cars horsepower / weight / and the width of the sand cars wheels - if all are relatively the same to a side by side they will be fine.
When I was grabbing oil for my 250r, I checked out the tensor paddle tire setup. I kinda liked them but I feel the paddle is a little to small for the setup I have...su prolite 4seater around 1600lb ish loaded, but with a 485hp 13.b rotary turbo, I think I'll wait to get some used blasters or padla's for a better grip in the sand..20221210_121320.jpg
