Just curious what an ideal temperature swing would be between the radiator inlet and outlet. My scenario is a LS1, CBR aluminum radiator with two 12” SPAL fans. Delphi computer cuts the fans in at 201 and out at 185 if I recall correctly. With the engine idling in 90° ambient air, my upper radiator fitting reads 205ish with an infrared temp gun (aluminum AN fittings upper and lower) while the lower reads about 180°. My fans run constantly once the engine reaches operating temperature in this scenario. This has lead to the occasional burned up fan relay. For reference the computer did have triggers for the fans to come on separately, but they have since both been wired together on the cooler circuit. The temp gun on the cylinder heads reads about 187~190.
