EastMT
- Jul 20, 2022
- 1,036
- 708
First on the list of things to figure out is why I cannot find 3rd, 4th , and reverse gears, when in neutral it feels like the shift knob will not go right enough to get to where the 3rd and 4th gates would be or left enough where reverse would be. Looking down at the shaft that goes to the transaxle below the shifter , when in neutral the shaft does not rotate any futher past where 1st and 2nd are. I cannot move the shifter enough the other direction to get to where reverse should be.
So where do I start to diagnose this problem? How do I determine if the floor mounted shifter mechanism is worn out or needs to be replaced? What information or pictures would be helpful to post?
