School me on LiFePO4 batteries conversion in RV
GmFamBam
My RV is due for new batteries; it currently runs 2 6v batteries. Want to upgrade them with LiFePO4, RV doesnt have Solar, we usually run the genny in the mornings for coffeee then again in the evenings while making dinner.
Can i just replace them with 2 100ah LiFePO4 batteries?
Will my stock converter/charger be able to charge them?
Or Can I just connect a NOCO or similar charger to them, and everytime the genny runs it will charge them?
Any advice is much appreciated
Would need to change the converter to LI compatible pretty cheap now a days
Yep, and depending upon which one you have you may just need to change a jumper setting on the board. I replaced my converter circuit board last season and the new one has a jumper that can be swapped in position to support lithiums.
Without changing the board out, the lithium compatible nocco is a ghetto option but you would want to full disconnect your converter from the equation so it's not beating up the LiPos at an insufficient voltage
I swapped to 2 100Ah LiFePO4 batteries about a year ago. These new batteries have a very low internal resistance and when the charge level is very low will tax your alternator charging system. I installed a Victron 30A DC-DC (much cheaper than Amazon on Marketplace) and it limits the charge current to 30A, and it also works with my older MH battery charger. The DC-DC will take a lower input voltage and increase it, and utilize a 4 stage charging scenario.
You get almost 2x the battery power vs lead acid or AGM because you can't discharge a lead acid battery past 50-60%, but a LiFePO4 will let you use almost 100% of its power, and maintain a steady voltage the whole time. Another benefit is the Victron has bluetooth and lets you see how the batteries are charging. I use one of these to keep track of the battery level, works awesome.
Check out DIY Solar Power with Will Prowse on Youtube for cheap but good battery recommendations. They have gone up a lot in the last year, I got 2 Wattcycle 100A batteries for close to $100 each last year.
