Rubbing or rattling sound coming from the bell housing, the sound goes away when the clutch pedal is pressed. Sometimes, when I first start the engine, it doesn’t make the noise for a few minutes. If I bring the rpm up, it makes the sound.
New S45 transaxle with 0 miles, new pilot shaft bearing. The clutch is a Kennedy 9” stage 4, 2 disc, was working fine with the previous TA. I removed the clutch and visually, I see nothing wrong with it. No metal shavings or signs of something rubbing.
Any input would be appreciated
