Video from today after presenting this to him.
Notable items in the guitar:
C1 Corvette 4 speed shift knob.
BB Chevy stainless roller rocker arm.
Bent pushrod from a customer engine that got bent that way. I blued the end and it looks super cool.
Bent valve the way it came out of a customer engine. (BTW in the amp there is a bent connecting rod from a customer engine. Forgot about that)
NEW BB Chevy never run 12.5 to one GM piston standard bore. Well half of one. lol.
Pair of roller lifters.
Snap on screwdriver.
Chrysler oil pump concentric which spins.
Vintage Isky cam lube in the the steel container. Have to think this is very old and was one of my dads collectables.
Brass carb float under the head of the adjustable wrench.
Beehive valve springs at the bottom and 3 Nissan valve springs from my VQ35DE Nissan motors.
KTM 400 Cam gear. Cool looking gear.
There is one heim joint in each piece.
Several 930 CV balls in both pieces. Some I hit with the torch to make the blue balls.
That round aluminum Ford logo came from one of the guys in the shop. I had to grind forever on the cam to get that to lay down low enough to make the strings work.
Clutch pivot arm ball.
Plenty of really neat gears and bearings.
Up top of course a gold retirement watch.
Not sure if the video will show it but there is an old champion spark plug key chain that I have had for probably 35 years. Just a fun thing I have always had.
Hanging from the top and the key chain piece from when my dad went on the 2017 Hot rod power tour. A very personal piece as well.
