wesinls
- May 6, 2021
- 619
- 755
My motorhome has a painted body but with vinyl graphics...has anyone removed the graphics and had them re-painted on? If so can you post pictures and who did the work?
I finished getting the graphics off of my trailer. The flat eraser wheel seemed to work best with the cracked graphics. But it left a glue residue that I scrubbed off with a scotch green pad wet with acetone and the wiped with a cotton towel wet with acetone.I’m in the middle of doing this myself. On one side, most of the graphics came off by letting them warm up in the sun and then peeling them off. I didn’t use a heat gun as I didn’t want to burn the surface.
On the more stubborn ones I used a razor blade and scraped them off in small strips very carefully. I ground the corners round on the razor blade so that they wouldn’t dig into the surface. I would also de-sharpen the blade a little with a file.
I still have some sun baked graphics that are cracked and won’t peel or scrape so a friend recommended an eraser wheel. I ordered this one from Amazon, there are many to choose from, and will give it a try after the holidays.
Worst thing about clear is if you don't go to an edge or seam it will leave an edge on the surface.then clearcoat it
I was the same way, but watching the graphics crack more each year I couldn’t wait any longer.nice work, hoping to do this myself this summer, but I've been saying that for 3 years now
I’ll have to admit, the ghost images are starting to grow on me.That's awesome! You can't avoid the ghost images though from the UV discoloration on the paint.
I wonder if you can now wet sand the paint to get an even color, then clearcoat it.
Mine are slowly become transparent anyway. Good things come to those who wait? :biggrin:I was the same way, but watching the graphics crack more each year I couldn’t wait any longer.
Glad I’m done now.
