- Apr 29, 2021
- 2,229
- 3,247
Im adding dual master cylinders to my brake pedal from a single setup.
Question I have. Front brakes are dual piston. Rear brakes are 4 piston.
With the new dual master and balance bar setup, should I still have a 5/8 and 3/4 bore set up (front and back) or go with the same bore on both masters and use the balance bar to make the difference?
