SANDFORME
- May 7, 2021
- 97
- 61
I have a 4 door Norcold model 1210IM. It has been leaking after letting it run for a couple days.
I checked the drain hose that goes to the outside and the little fitting in the hose and both are clear.
The water is actually leaking from underneath the fridge where the lower mounting trim is screwed in. There is like a plastic part that mounts to the wood cabinet to dress up the edge where the fridge is installed. Its leaking from there? Everything outside looks dry and seems to fine.
Im thinking I have to pull the fridge to see? Anyone have any ideas before I try removing the fridge as it seams a little involved. It seams that anything that could leak would be on the back side? The door seal also looks to be fine.
[SIZE=13.3333px]Any Ideas would be appreciated. [/SIZE]
