Kingkong
- 12
Any one got a set of 1/2 wheel spacers new tires barely rub locked out right turn 8582545653
I have 3/8 spacers right now and it's worked for years if I use the 1/2 my lug nut would be flush with the stud when tightened I'm assuming that should be good enough... I never fully lock out unless maybe I'm turning around or something I just don't wanta ruin the new tires lol.. I went up a size smh.. how long you gonna be there for? I will be in glamis on Tuesday for vetsI think I have some. I should be in glamis this weekend. One thing to check though is if you studs are long enough. Mine weren’t which is why I didn’t use them. And remember when duning it’s rare to go full lock to lock.
I’ll be back out Wednesday for vets too.I have 3/8 spacers right now and it's worked for years if I use the 1/2 my lug nut would be flush with the stud when tightened I'm assuming that should be good enough... I never fully lock out unless maybe I'm turning around or something I just don't wanta ruin the new tires lol.. I went up a size smh.. how long you gonna be there for? I will be in glamis on Tuesday for vets
How much? I'll be on geckoI’ll be back out Wednesday for vets too.
Same. Let me make sure I have the 1/2” ones. I know I drilled out the holes for bigger studs. A case of beer would be plenty.How much? I'll be on gecko
DealSame. Let me make sure I have the 1/2” ones. I know I drilled out the holes for bigger studs. A case of beer would be plenty.
