wesinls
- May 6, 2021
- 652
- 808
I wonder if you can use it with the Holley or other engine management to cut out a fuel pressure regulator as well...? Ford's been doing this for years with their returnless fuel pump setups: no fuel pressure regulator, just use the fuel pressure sensor to control fuel pump output in real time. Especially useful if you have a monster pump and are just pumping it through the regulator constantly heating it.I have used them on a few cars, and as @Rockwood said they are great for controlled PWM devices (I use these with the Holley ECU), but what I like is that if one does fail as long as you put a service loop (and battery cutoff switch) in the wiring you can jump the SSR if needed
I use the Leash relays and boxes on some cars because they have 70amp SEALED relays and have a fuse, super convenient for an add-on situation.. also their fuse boxes are self contained with 70 amp relays and fuses ands have a LED that indicates a bad fuseSeveral guys in our group are running Leash relay boxes. The Leash is pretty versatile and I like the set-up. Can't comment on the MSD stuff cause I have no experience with them.
BUT, the whole thing is only like $25.I use the Leash relays and boxes on some cars because they have 70amp SEALED relays and have a fuse, super convenient for an add-on situation.. also their fuse boxes are self contained with 70 amp relays and fuses ands have a LED that indicates a bad fuse
The downsize is a failed relay can only be replaced by Leash (or you can desolder yourself of course)
Inflation’s a beeyotchBUT, the whole thing is only like $25.
https://leashelectronics.com/products/single-70amp-relay-moduleInflation’s a beeyotch
https://www.speedwaymotors.com/Speedway-Single-70-Amp-Relay-Module,404373.html?utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjwvfmoBhAwEiwAG2tqzGIbh5p-QMw1erYKY7ia0ioHfcbsUSe2QY6QvnTJzgl9qM4wre8bPxoCkXYQAvD_BwE
With the fuse at least. :biggrin:
Single 70 amp relay module. Has heavy duty 70 amp industrial relay. Uses heavy duty J-case/FMX fuses (NOT INCLUDED).
Neither of them come with the fuse.Single 70 amp relay module. Has heavy duty 70 amp industrial relay. Uses heavy duty J-case/FMX fuses (NOT INCLUDED).
That's why I ninja-edited it to say "with the fuse at least"... LOL
