matt86m
- May 6, 2021
- 1,157
- 1,345
Going to pull a Jeep behind the MoHo.
Diesel pusher with air brakes, looking at the Roadmaster, Brakemaster. There are 2 models, 9100 & 9160. The difference is a break away system on the 9160. In the unlikely event that the toad separates from the RV it will have an air tank of its own to apply brake pressure to stop the Jeep.
The 9100 doesn't have a braking system of its own for the toad.
I will be using safety chains.
My enclosed and 5th wheel had break away systems. The enclosed has safety chains, none on the 5th wheel.
If I didn't attach the coupler to the ball correctly and it slipped off I'd have chains to keep the Jeep with moho with no break away system.
If the same thing above happens with a break away system the Jeeps brakes will activate and I may drag it a little until I realize there's something wrong.
There is a price difference of $145 but that's not the concern (not after buying an RV & Jeep!)
It's having to mount the air tank (although small) on the Jeep.
SO, Question:
Do you have a break away system on your towed car?
I have been told some states may have a requirement for a break away system but isn't that what the chains are for?
SO, Question:
