HydroPower
- May 10, 2021
- 67
- 28
Upgraded my sand rail so have these parts to get rid of.
Mefi came out of running twin turbo LS3 car tuned for pump gas. Custom harness with bulkhead disconnect making it easy to pull motor without having to un wire. Harness also comes with bussman relay and fuse box setup for fans and fuel pump. $700
Livorsi gauges- water temp, oil temp, boost and oil pressure. All gauges are complete and working $225
Remark gear indicator, wires are cut but can easily be spliced back together. Does not come with the trans potentiometer. $150
Im in Nor Cal so shipping on buyers dime but should be cheap with flat rate boxes
