Magnusson Supercharger for LS1, Heat Exchanger, Intake
lincster
I went up to a bigger supercharger this summer so selling my whole system.
1.7L Magnusson for a stock LS1, F body belt line (Camaro).  This blower was designed by Magnusson to bolt directly onto a stock Camaro.  I was getting 6.5lbs of boost on my LS1.
I sent the blower to superchargersonline and had them rebuild the entire thing before I used it.  Everything was new including rotors.  They also polished the rotor housing, fuel rails.
Injectors are included.  They are 80lbs/in Bosch injectors.
I used my old TB for my new blower, a 90mm.  You can get them from Holley.
Including my heat exchanger that has 8" Spal Fans (pullers).  Heat exchanger is 30" wide X 8" tall, 3" thick.
Also including both of the pumps I tried.
Including my intake that I had fabbed to work with the new setup.  Bolts directly to the heads on a LS1.  4" tubing.
I also have my old lines the may work for someone, depending on where you put the heat exchanger.
$4000 for everything.
Call or text, 480-231-6386.
I am in East Mesa.
cool!  GLWTS  what's the new boost?
I got 13lbs out of the 2.3L.
I went 1:1 on the rear pulleys and went down to a 2.8 on the front.
Those pulley changes went from 8 lbs to 13lbs.
