Mellen_GTX
- May 6, 2021
- 37
- 40
Ls7 440 with 4.0 whipple. I've been doing my oil every 4-5 dune days. When should I be doing plugs and wires?
Ngk v power 8sAre we talking about a motor that normally, in a car, has a 100,000 mile tune-up interval?
Talk to your builder, but I'd say years....But, we are talking about less than 20 bucks...You are running standard plugs right. You should be....especially if you are going to change your plugs every year.
I bought a set of 8 NKG plugs for a client in Glamis for $90 at NAPA in Indio.Are we talking about a motor that normally, in a car, has a 100,000 mile tune-up interval?
Plugs, maybe every time you start it or every couple of years, there is not builder recommendation or schedule out there, this is a Hi-performance motor, so common senses will play the best role, a lot can go on with a motor from trip to trip, on a boosted motor it would be best to pull a plug more often to make sure everything is looking good, if you pull a plug and something looks off, then pull more plugs, you will see any detonation issues from reading a plug, On a boosted motor i pull a plug from each side every trip, on Heavy Boosted motors like 21-23lbs i pull a plug every day.Ls7 440 with 4.0 whipple. I've been doing my oil every 4-5 dune days. When should I be doing plugs and wires?
