J Alper
Site Sponsor
- Apr 30, 2021
- 1,773
- 1,527
[SIZE=18pt]LS-7 434-Ci DARTON SLEEVED MOTOR [/SIZE]
LS-7 Darton Sleeves – stroke and bore is 4.00’’ x 4.155’’
Sleeves can go to 4.185
NEW 2618 Forged Pistons DSS FX2 15CC Dish Steel Top Ring 1.2 x 1.2 x 3mm
LS-7 Titanium Connecting Rods – Factory 12 point rod bolts
LS-7 Factory Forged Crank - Rebalanced for 4.155’’ pistons
12 point Flywheel bolts NEW
Clevite Main Bearings and Rod Bearings with Main Studs
Durabond Cam bearings
Comp 850-16 Lifters NEW
Factory AC-Delco Lifter Tray NEW
Chromoly .080 Pushrods
Tatum Motorsports Venom Camshaft .600 lift
Comp Dual Spring kit 155lbs seat – 450lbs open NEW
Valve Seals NEW
LS-7 Factory Rockers with Trunion Kit by PRW
Factory Balancer with 12 Point Pulley Bolt
Factory windage tray
Factory oil pump
Dry Sump LS7 Oil Pan
LS7 Factory Heads with Titanium intake valves
Stainless Steel Head Gaskets
GM LS2 Coils
Top Street Performance Valve Covers and Seals NEW
Bosh LS-7 Fuel injectors 0280158051 NEW
Top Street Performance Sheet Metal intake
New fuel rails with cross-over line
92MM Throttle body with Sensors
Billet Valley cover, powder coated black
Billet manual tensioner
Billet Power steering bracket
Sweet Power Steering pump 1450psi
LS2 F-body water pump NEW
160 Degree Thermostat and Chrome Housing
C-130 Alternator NEW
F-body Alternator Bracket GM
GM Performance front and rear seals
Head Studs with ARP 5/8’’ Socket Nuts upgraded from the 1/2’’
Motor comes with the following sensors, (Crank, Cam, CTS, MAP, IAT, TPS, IAC
NKG Spark Plugs
Taylor Spark Plug Wires NEW
Billet Steam Ports and block offs
Hardin Marine Idler and Tensioner pulleys NEW
Stainless Steel Header Studs
[SIZE=14pt]$12,400.00 OBO [/SIZE]
Valve Seals NEW
Factory oil pump
GM LS2 Coils
NKG Spark Plugs
