Cable Guy
- Jul 13, 2021
- 33
- 11
I have an LS2 that only has around 25Lbs of pressure when cold after engine and oil are hot I have 0 oil pressure.
Here’s the kicker when I went to change the oil and after draining the pan, I removed the oil filter and there must have been at least half a quart of oil that flowed out over the filter. I have never seen that before.
Thinking clogged filter was my problem, I replaced filter and still low pressure. When I pulled the new filter, again half a quart of oil or more flowed out over the filter.
Anyone ever had this happen? Is there something clogged?
[SIZE=11pt]I am getting ready to drop the oil pan and check O-ring on tube feeding pump just to make sure it’s still good[/SIZE]
