wesinls
- May 6, 2021
- 963
- 1,220
I'll soon be adding an LS3 to my car and assume that i'll be needing to do something similar to the below picture - more or less re-route the inlets / outlets to be a more favorable angle. Is this something that I should expect the builder to take care of, or is there a place I should work with to modify the stock water pump? FWIW - I'm having Alumicraft mount engine and Redline Performance tune the car once the engine is installed...just trying to figure out what I should do or not do on my own. There's a ton of water pump options too - and people blocking off the heater core lines a few different ways...
If anyone has a water pump they'd recommend for an LS3 considering the motor will be a mid-engine it will be appreciated...i plan to also ask the car / engine builders but always appreciate the advice on this forum.
