Glamisdude
- May 6, 2021
- 88
- 38
Hello GD,
I have a S4D on a twin turbo 440 LS motor the makes 1100 wheel. I am currently using the weddle/centerforce racing double 11 clutch. When I first switched to the Chevy bellhousing and this clutch a couple years ago I setup the pedal stop for the internal slave as directed by the instructions. But I noticed soon after that I would have to adjust my stop further and further to stop the trans from clanking into gear. I have now completely removed my adjustment bolt and it’s starting to get a little much as far as the initial into 1st gear shift. Also what is weird is it seems to be worse after driving. Cold In the morning will be a somewhat of a smooth shift. Hot after driving it’ll SLAM into first. Idk..
So I am floating the idea of pulling the engine in the next week and swapping in a new clutch, maybe a McLeod if I can get one and putting a dust shield on the bottom side of the flywheel. I am thinking maybe some sand is getting in there.. idk I’m at a loss
I have also already changed my master cylinder. No change
Any help is appreciated
-Landon
-Landon
