Dzrtrat1111
- May 7, 2021
- 94
- 103
My car felt down on power this weekend and could smell fuel in the exhaust. LS3 376/525 with Mefi 4b and CMB harness.
Took a temp gun to the primary tubes and the left bank (cyl 2,4,6,8) were only in the 200 ish deg range while right bank were 700 ish deg. Pulled the plugs and found that the left bank plugs looks fouled and right looked normal. I replaced the bad plugs and checked the coils and injector harness connections with no change in the way it was running.
A little background, I just finished a full tear down to paint the chassis because it was still raw chromoly and was tired of fighting to keep the rust to a minimum. I painted everything with Steel-It.
Could a poor ground connection cause just one bank to run like crap or am I looking for a bigger problem?
