What works in super dusty conditions like a bumper pull trailer? Heard of the penny. Need to try that.
The Trojan battery guide videos online with the old lady host recommend coating everything in vasoline. Been wanting to try that too. Just dont want to deal with cleanup. I keep hoping a nice clean dry connection will work. But it never works. My truck or trailer.
At least with a dry connection the cleanup is using baking soda water. The terminals are not coated in a grease to clog up my wire brush. But maybe thats the way to go? Coat everything in dielectric grease? That part confuses me too. I read mixed advice on when to apply dielectric grease. I still dont understand how you could coat a terminal and then expect it to scrape off completely as you push the connector together. Wouldnt there still be a super tiny film of atoms left between the 2 metal surfaces? I use dielectric grease often. I will fill the entire connector and then push the terminal in. Let the excess plop out. For the trailer tongue batteries im not sure grease is the best choice. Curious what you guys do. This time i might end up coating everything since the clean and dry method keeps failing.
