Ganzo
- Jan 1, 2023
- 72
- 7
Hey guys whats up? So i was wondering what you guys do to bleed your cutting brakes? I have the jamar cutting brake that i put in my baja but could bleed it properly. Any suggestions? Thanks
What he said :thumb:This is what I do:
Push down the brake pedal and then push and hold the cutting brake lever.
Purge the air from the caliper.
close the bleeder but continue to hold the cutting brake.
release the pedal but not the cutting brake.
pump the pedal slowly, allowing the cutting brake to return but with hand pressure against it until the pedal pumping has pushed the cutting brake handle back to neutral.
start process all over again.
Ok so i will try this and if this doesnt work out i will get a pressure bleeder. Thanks guysThis is what I do:
