AlpineFunco
- 928
Ok, I’ve had a Gen 3 all these years. Just got a Gen 4 and it’s time to take things apart. Got the trailing arms off, had to use a sawzall as two of the bolts had welded themselves to the bushings.
On to the Cv’s. Got them out, soaked in diesel, and wiped down. Not super impressed with how they look, but I may be able to squeeze another season out of them before replacing.
The hubs; got most of it apart. Got the CV body out and the bearing that it goes onto it. got the inner piece that it bolts to out and wiped down as well. Pulled the 5 bolts that hold the housing to the trailing arm and thought maybe it’d just pop out like everything else, but it didn’t.
So the question of the day is will it take a press to get that out, or more importantly get it back in? I don’t mind beating on it a bit but don’t want to eff anything up. And if it’s going to take a press to put it back in then there is no sense in me beating it out. Arms are going to Funco to have uniballs welded in, so I could probably just have them do it if it’s going to turn into a big pain in the ass.
