RPMsRUP
- May 11, 2021
- 83
- 66
Where is everyone installing the compressor tank in a Gen 4 and what size? pictures if you have them thank you
What isze tanks are these? this a perfect setupI've done several and put the tank and compressor under the passenger seat.
This isn't one I did, just another example.
Not sure. I buy the Air Lift kit from @Grant@Funcowith their upgrades. Piecing a kit together to save a few $$ will not be worth it in the long run. Done it twice for clients.What isze tanks are these? this a perfect setup
ok cool thanks for the heads upNot sure. I buy the Air Lift kit from @Grant@Funcowith their upgrades. Piecing a kit together to save a few $$ will not be worth it in the long run. Done it twice for clients.
The air tank has brackets welded to it but I cut them off so it will fit under the front passenger seat. I use large long zip ties to hold the tank to the front mount for the seat. It's not structural, it's not heavy. Zip ties are fine.How are you attaching the tank to the floor? I think I saw a post where nutserts were used in the tank.
