HTElectrical
- May 6, 2021
- 238
- 86
What is everyone using to protect the charge wire from the Alt. to the Starter? Fuse, Fusible link? What size wire, and Alt. Rating?
Thanks in advance.
Thanks in advance.
i agree, on a Subaru the wire is only 2' long, not long enough to worry about a short on the wire. and a short in the alternator to ground is very rareKinda pointless unless its a very long run, then I would use a blue sea terminal fuse. The fuse is in the connector.
That is what I used with a 100A fuse. It looks like one side might of loosened up and overheated causing the fuse and holder to fail.Circuit breakers like Rockwood noted above are nice because they are resettable, but the are big and can be contaminated with sand and dust. IF I were going to protect my charge wire it would be with a fuse holder like this, then pick your fuse amperage and buy a couple spares.. FFIW...Waytek is a great source for electrical goods...
