Fuel Pressure Regulator Vacuum Line - Needed on NA Engine?
wesinls
Anyone using it - and if so where are you plumbing it too...stock LS3 intake in my case.  Or are you just capping it?
Aeromotive 13105 in my case
Pretty sure it's to boost reference the regulator on a turbo or blown application. It allows the pressure to rise when it sees boost
updated subject to indicate its a NA engine in my case...mixed opinions of using it on various LS street forums.
goes to manifold. NA or boosted app the reg will add fuel pressure under load.   im no tuner and im sure you could run it either way as long as the engine is tuned for it
This is a boost reference regulator. Unlike a "typical" vacuum reference regulator, it increases pressure with boost to over come the intake manifold pressure.  A vacuum referenced regulator increases pressure with decreased vacuum, "load".  As the "load" on the engine increases, vacuum decreases to near atmosphere.
On a boosted system, to keep fuel pressure at a +1:1 to manifold pressure, fuel pressure must increase at the same rate of boost.  Otherwise, if you had 40lb of boost, and 40lb of fuel pressure, you could effectively have zero fuel leave the rail.  At 40lb of boost, you would need 80lb of fuel pressure to be equal.
To answer the OP's question.  It will work.  Your tuner just needs to know what you have, and plan accordingly.
Whatever it’s tuned for. If you’re tuned for it and don’t use it, it’ll need a lot of correction at part throttle/idle.
I’m not sure there is a vacuum vs pressure regulator. I think they all compensate for both. All non turbo subaru ones work the same as turbed ones. The tuner would not need to know if it was connected or not. He would tune accordingly. It would be an issue if they were just “ installing’ a base tune that expected it to be connected and it was or the opposite. The whole principle is to be able to get the injector in a better fueling range. When the regulator sees vacuum it lowers fuel pressure that makes the injector flow less for the same amount of injector opening   So the tune can be more precise. Like getting a drink of water from a faucet vs a fire hydrant.  When you are full throttle the vacuum goes to almost zero thus increasing the fuel pressure which is perfect for larger loads. It then works to still increase fuel pressure even more in boosted applications. Like kraut said most don’t think about the delta if pressure across the injector nozzle. In an NA motor the fuel is being injected into a vacuum. In a boosted motor the injector now  squirting fuel into a pressurized system. Make the injector “look/act” smaller. Typical regulators are a 1 to 1 rising rate. So 10 psi of boost raises fuel pressure by 10psi. This ratio may be linear but the flow rate of injectors are not so   Adding 20% more fuel pressure does not net 20% more fuel flow from the injector but it is a step in the right direction. For fueling
Vacuum is just pressure  with a different reference point.
I would not use it, it makes the fuel pressure unstable for non boost, everyone wants to run 91 octane, and not race fuel, so motors can be on the edge of detonation depending on the tuner, why add more complications to fuel pump/pressure issues, This is a boost reference port, for boosted cars it will ramp up the fuel pressure to allow more low to high flow on the injector,
Looks like ALOT  of "opinions" here. Most have the answer I'll add the color if you care...
What I can tell you is doing this wrong or changing this CAN destroy your engine.  Not opinion, just fact and the recommendation of various manufacturers
From an ECM/tuning aspect, you should always whether Boosted or NA always set fuel pressure with the line disconnected. Full stop doing it another way will provide incorrect fuel pressure numbers
In an EFI engine fuel pressure determines how rich or lean and engine runs.  depending on the cam and compression the Vacuum at idle can be 10-25 inches of suctions and part throttle at 5 ish and 0 at WOT
the vacuum pulls on the diaphragm of the regulator and will change the fuel pressure  - you don't ever want fuel pressure changing as you drive - you want the Fuel map in the ECM to control how munch fuel the engine gets. - not the vacuum ( well thats how a carburetor works actually).
Imagine with the line on at idle your fuel pressure is sitting at 43.5 because your tuner set it there (like he/she should with the line off)   now its 38Lbs with line on with the line on and 20 inches of vacuum car runs at 16:1 AFR (its way lean and ecM if it has compensation or learn (basically all modern ECMs) is throwing in fuel to bring it to the 13.8 or so the tuner set - you just F'd his/her/they/them:-) fuel map. -  Now you romp the gas vacuum goes to zero your fuel pressure goes to ~ 48LBs - this messes with your AFR. and the ECM starts pulling fuel out like a Mofo  and your tune is all messed and you blame the tuner for black smoke and loss of power , a hot running idling engine and an overall crappy tune  - just because of a little vacuum line and believe me its now the first place I look, but it took a while to get to that conclusion.
When I get an NA car with line on in to me to help tune - I drop a BB in line so I don't have argue with the person and tune the car the right way.
 - A little more info.  - The manufacturers say the port on NA applications should be open to atmosphere.  If you attach to vacuum the Fuel pressure will be reduced at Idle and part throttle as vacuum will pull on the diaphragm.
This will affect the full map and tuning on the car.   This also affects the spray pattern of the injectors.  Most injectors are made ti see 43.5lbs MINIMUM to have good spray pattern (aka smooth idle). and can support upward of 100lbs   (boost referenced). but they usually work best between 43.5 and 60lbs
If the regulator had the line attached to vacuum and car was tuned that way leave it - removing vacuum will change the fuel map and vice versa - adding the line  after the tune will change the fuel map
The easiest way to burn down and engine is to mess with the tune
While I do 90% + boosted cars, on NA cars I leave the port open  and with run a "snail" turned piece of tubing pointed down and away from the headers or buy a screw in air filter  (stone filter) as JALPER does and usually thats if the regulator is away from the engine
On a boosted engine running a line is a MUST  - you have to boost reference the fuel -  think of it this way  - if my fuel is at 60Lbs and I add 10Lbs of boost I have effectively reduced my fuel pressure to 50lbs and I seriously messed with the tune.  So I set the fuel pressure with the line off  and adjust the fuel map with the line on  - and I have full control  -
The only bad thing on boost referenced regulators or regulators with line attached or a line at all is if you burst the diaphragm  (ethanol can do that on older Areomotives's the port  shoots gas out like a small fire hose  - so watch where you mount it if open and it connected to the engine. it pours fuel into the manifold and can hydro lock the engine (ASK ME HOW I KNOW :-( )
As said regulator are almost all 1:1 rising boost to pressure, Then there are FMU'as and thats a whole different game 10 to1 or 20.1   .. I am not going there ...here
But to the OPs specific,  that 13105 is an awesome NA regulator its my goto, but be careful where you buy it - aeromotive stuff is 100%  being knocked off and the knock offs are very unreliable
https://aeromotiveinc.com/buyer-beware-genuine-aeromotive/
I hope that long explanation helps.  take it or leave it FWIW
What would be the adverse effects of capping that line?
if you cap it, you have "some" pressure against diaphragm  and can "slow" the regulation.   You have to remember these are Bypass regulators so they should be placed "after" the fuel rails so the pressure is consistent - when you drive up RPM more fuel is used (fuel is pulled by injectors out of the rail) sir the pressure drops and regulator has to close up, and that action is slowed because as the diagrapghhm drops it cannot balance the air pressure on the "closed side"   - you always need air coming in to replace the volume left when the digraph drops and you need to push air out when diaphragm comes up.
does that make sense?
Absolutely. Thanks for the explanation.
