Dockmaster
- 1,031
My 26' enclosed trailer has two 40 gallon fuel tanks. The tanks are mounted over the axles and the pump is mounted in a compartment at the front of the trailer. There are 1/2" typical fuel hoses running about 15' from the tanks to the pump. The pump is rated to pump 5 gal/min but I'm only getting a little under 2.5 gal/min. The auto shut off on the nozzle doesn't shut off and the theory is the flow is too low to activate the shut off. The discharge ports on the tanks are 1/2" and the input on the pump is also 1/2". My question is; if I increase the hose size between the tanks and pump will I get increased flow? Or will the flow still be restricted by the 1/2" fittings on the tanks and pump? The 1/2" hose takes a few ups/down as it clears main cross members. My thought was to install a straight run of 0.5" nominal aluminum tubing (0.622" I.D.) welded through the cross members and get it as close to the tank and pump as possible. Then use the 1/2" fittings as close to the tank and pump as I can reasonably get. I'm thinking by having a straight shot of tubing with a little larger I.D. the flow resistance should be pretty significantly reduced thereby increasing flow? Or would this all be a waste of time as the flow is still going to be what it is now due to the 1/2" sizes at the tank and pump. Surely the pump must be capable of more flow even with the 1/2" inlet or how could it be rated to 5 gpm?
