Dockmaster
- 963
I believe there are quite a few heavy equipment guys on here so I figured a good place to get some input and advice. I have a 5.5 acre property in Central Oregon. It has a lot of rock on it. I want to use the big rock to build a retaining wall then fill in behind it with the small rock. Some of the bigger rocks weigh around 5000 lbs, most are going to be half that or less. The area I want to put a wall will extend out from where the property slopes down. My wall will be a half circle of about 15’ diameter and and a little over 10’ tall.
My questions are:
1. How big of an excavator do I need to handle rocks up to 5000 lbs? I was thinking to buy a decent condition used machine then sell it when I’m done. I have some experience operating but not a ton. It’s hard to find true lifting capacity specs and I don’t want to push a machine to the limit or only be able to pick up a rock between the tracks. I was thinking something like a Kubota EX80 or maybe even an older Hitachi 120.
2. Should I go rubber tracks or steel? I have existing dirt road that I would be operating on most of the time. I prefer not to tear up the road any more than necessary. I will need to travel over some uneven ground to pick up some of the rocks.
3. As I fill in behind retaining wall with rock, do I need to add fill dirt to help fill around the rocks? Once I’m at my grade level I plan to finish the area off with 3/4 - gravel and make a fire pit area. I was thinking if I don’t use dirt as I fill I run the risk of little sink holes as stuff settles between the rock?
Here’s what I’m working with and the area I want to fill in. Basically, where you see the rock slope in second picture, I want to extend that out about 15’ in a half circle.
My questions are:
