r3meyer
- 235
So I figured I would ask this question here because IRV2 has been no help and there are some really smart guys on here that know this combo.
I got a new to me 03 Monaco Dynasty that has the 400ISL cummins and allison combo. This coach has a true 2 stage Jake brake on it. Low activates the first 3 cylinders and then high activates the remaining 3 giving you 6. At least that is what its supposed to do. When you activate the jake brake via the switch the allison selects the 2nd gear and then the coach will start to down shift. I thought everything was working fine until coming home from Moab. The jakes are not working at all. The coach will snow ball down the hill making it not fun at all.
I have checked both of the solenoids and they both work if I give them 12V. I had a friend drive while I tested both banks and when you activate them its very noticeable as the coach really slows down.
What I cant figure out is why the transmission is down shifting but I am not getting a 12V signal back in the engine. Anyone know this system?
