matt86m
- May 6, 2021
- 1,157
- 1,345
http://www.coltontruckterminalgarage.com/ - Took great care and I highly recommend them!!!
Took our 2000 Country Coach to CT (Colton Truck - from here on out) for their chassis inspection. We already bought the rv but they do this for pre-purchase a lot. I wanted to have a good baseline early on and continue to keep good records like the original owner.
They check pretty much everything on/under the chassis and the generator. They don't do 'rv' things like slides, roof ac's, etc.
They found and fixed a few smalls, leaky diff bolt (dented), couple hose clamps weeping (tightened) hub fluid too full, engine oil 3 quarts low, inspected and adjusted the brakes, shocks, and a lot more.
Took the time to explain things to me that I was unfamiliar with. Answered questions and gave advice.
On the way up the AC compressor froze and spit the belt - the ac wasn't great before this, maybe it was going out. I'll have to bring it back for that fix. Parts have been ordered and appointment made. Hopefully the Ford AC (dash) will blow better once the new stuff is in.
Rich and his brother (didn't get his name) own the business. All the employees were great, helpful, polite and all seemed to like working there. Busy operation! Lots of RV's and a few semi trucks but every bay was full and some work going on outside.
Appointments ARE needed!!! About a month out at this point.
Just wanted to give them a shout out. Call them if you are buying a moho or have one that needs a good once over.
Now if I can find an RV place that is good with slides and all the other RV stuff!
