Chenowth 4LWD. Honda, Dual Kings, ***Massive amounts of fab work****
fordfreak
This buggy recently has gone through some serious fab work and money and I’m probably forgetting to mention it all. All 4130 lengthened rear, engine/trans 5 deg, raised sides, raised front frame and hood tubes to clear 16in travel, and engine/trans setback for 3x6 trailing arms. This buggy is very fast and handles desert whoops like a race car. A lot of time and money has gone into this build. This is the car for someone who’s very anal about quality, can appreciate quality fab work, and wants to rip.
Engine:
•Honda 3.5L V6 from Marked Motorsports
•Stainless large tube headers
•Custom rewired ECU harness
•Reversed and machined intake
•Ports/EGR threaded and plugged
•TracTuff remoter oil filter housing
•P2R billet water flanges -16AN
•New timing belt
•Water log removed and converted to all -16AN
•C&R inline thermostat
•CBR radiator with twin Spal fans. All fans are on temp sensors and relayed.
Trans/Drivetrain:
•Fresh 5 rib trans with Weddle gear set
•Kennedy Engineering adaptor and Stage 2 clutch.
•4.57 ring and pinion
•Ratios- 1st 2.91, 2nd 2.23, 3rd 1.63, 4th 1.21
•GKN 930 CV’s. Extensive prep, polished and tumbled
•Chromoly over-bolt bates boot flanges (new style) with RBP boots
•Sway-A-Way 300M axles
Front Suspension:
•2” x 4” Chromoly 4130 tig welded arms .375/.188” wall
•6” over chromoly 4130 beam tubes .188” wall
•2” x 10” King coil overs
•2” x 10” King double bypass shocks
•SACO billet steering rack 5/8” heims
•220w electric power steering with Sweet u joints
•Chromoly 4140 raised spindles with Foddrill 1.75” King Pins and bushings
•RBP Mfg spindles
Brakes:
•CNC brake pedals
•CNC clutch pedal
•CNC turning brakes
•SACO front 2 piston CNC calipers
•SACO rear 4 piston CNC calipers
•RBP brake rotors and hubs
•Steel braid/hard lines.
Rear Suspension:
•3”x6” Chromoly 4130 trailing arms
•33 spline micro stub hubs
•2”x10” King coil overs
•3”x14” King double bypass shocks
•Limit strapped
Fuel System:
•1/8” 5052 aluminum tank with welded baffles and sump. Return style.
•Aeromotive triple stainless filters, all AN, with Bosch 044 pump.
Wheels/Tires:
•Front CSM wheels with correct backspace for proper scrub radius (no bump steer)
•Shaved and balanced tires
•BTR beadlock wheels with Mickey Thompson Baja Pros
Other:
•Kenwood TK-890 100-watt UHF radio. Programmed with race channels, GMRS, and FRS
•Rugged intercom integrated with radio and PCI Trax headsets
•Powered whip mount
•Autometer gauges
•Suspension seats wrapped in new black tweed
•CROW 5-point harnesses
•Tempered glass windshield
•LED light bar and micro-LED interior lights
•New fiberglass front hood from original Chenowth mold
•Full aluminum body and dashboard
•Body is powder coated and frame/suspension is painted with
Steel-it
•Fire extinguisher and mount
•Billet rear view mirror
$17,000
Or trade for modded Jeep
oh I just realized the site wiped. I'm not new... So sorry my first post on the new site is a sales ad. lol Joined in 2010.
Solid looking Chenowth 4LWD, they keep going and going when done properly.
GLWTS
Love these cars. My first buggy was a 4lwd and now my close friend owns it up in colorado. Followed your build progress on instagram. Definitely some top not fabwork and major attention to the details. Someone will be getting a killer car. GLWTS
GLWTS
You ain't lying! The original plan was just mild suspension and built vw. Then it snow balled from there and ended going all out.
Welcome back, didn’t realize this was your build (saw the build elsewhere).
Good looking rail. Just to confirm, this has the 002 5 rib trans (one year only, 1975) Not a 6 rib 091?
How long since the shocks/bypass have been serviced?
Thanks,
Nate
Thanks,
Nate
5 ribs were used from 72-75.
It's just the 5 rib case. It has the 091 pinion and gear sets from weddle and 091 pinion bearings.
Seals were replaced about 3 years ago when I was doing shim and spring adjustments. Car was taken out maybe 4 times during that period.
Thanks bro! Just found you on there!👍
