Bobalos
- 5,484
Morning folks, my PSD has a dual MC setup with swinging peddles & a balance bar. I cant get a good peddle on it @ all. I thought it was simply a function of bleeding them out, but Ive bled them a bunch & while I can get it "better" its not by any means, "right". Im fairly certain that is the rear by looking @ the balance bar & seeing how far the piston goes into the MC.
Here is how its setup. Is it right that the rears with the larger Calipers should have the smaller MC bore?
Rear MC: 3/4", 6 piston Gear one calipers
Front MC: 7/8", 4 piston Wilwood calipers, (remote reservoir)
Throwout MC: 3/4"
Im Fairly certain that I have all of the air out. I have bled it so much Im getting brand new clear fluid out of the bleeders @ the calipers. I used my vacuum pump to suck as much air out as possible & then the wife & I did the "pump & hold" on it quite a few times. She's done this with me for almost 30 years, she knows what a good peddle should feel like & she gives me pretty good feedback.
FWIW, the rear calipers just came back from @parker@gearone who put bleeders in the tops of one of the calipers that did not have them & rebuilt both of them, so Im pretty certain that the calipers are all good.
Im have convinced myself that the MC for the rear is just crap. if its air you can normally pump it a few times & the peddle feel, gets better, but this never does. its crap every time you push it.
Does anyone know if anyone sells rebuild kits for 3/4" CNC master cyls?
Does anyone know if there is an off the shelf Master Cyl that has the same bolt flanges as the CNC products, so I can replace these?
Does anyone have any suggestions, on what to try next to see if I cant figure out if the MC truly is dead? if I put a gauge on it, what kind of pressure should I bet able to get out of the MC?
Below are some pictures of what it looks like if that helps any....
thanks
Bob
Throwout MC: 3/4"
thanks
Bob
