J Alper
Site Sponsor
- Apr 30, 2021
- 1,773
- 1,527
If you can afford a transaxle anymore, it gets you in the sand,I guess if you didn't want to wheelie and just dune this would be ideal.
abc
Seeing more and more front engine builds recently. Can save a ton of money not running a transaxle; though the hung member does add to cost/complexity if irs is wantedSorry Fat Fingered that one, Cant afford a transaxle, then this would be a good way to build a car,
UR gonna need a 10"+ ring gear if you really want to handle any real HP/paddles. That really limits the selection of IRS set-ups - although the Ultra4 guys are running some insane 3rd members.You can put a hung IRS member from a bunch of dif SUVs, like, I think, Expedtion, Exploder, Suburban (maybe), Nissan Armada, maybe Pathfinder, Sequioa....I think on all of those, and I am sure that are more. The Q, what sort of R&P do they come with.
The Ford 9'' housing will except a Pro 9 Gear that is a 10'' gear, but the automatic will be easier on the ring and pinion, the pro 9 are used in Top-A cars making 3500-HP and also used in some Desert Trucks running races all year, My Favorite is still Kevin DD car,UR gonna need a 10"+ ring gear if you really want to handle any real HP/paddles. That really limits the selection of IRS set-ups - although the Ultra4 guys are running some insane 3rd members.
