"KISS", keep it simple stupid
The way we would route this same motor uses 2 less hoses (think $100 wasted) and looks cleaner there is zero issue with our setup unless you are approaching over 600 hp
Think of any inline 4 cylinder motor with a single long fuel rail....if it was that important then why doesnt everybody iincluding the manufacture intersect the long fuel rail at the center (between cylinder #2 and #3) ?? well because its not needed.
Argument: sure the H style of fuel routing makes sense but if you are feeding the entire engine through a -6 line from filter to rails, then having a -6 line between the rails is good enough. now if you had a fire breather and was pushing 700+ then the main fuel line should be -8 and the tee off to two -6 to each rail.
but if you like spending money on two more hoses and keep the system looking busy................
