BASIC BLUETOOTH / REMOTE WHIPS
5150 Whips
 STANDARD BLUE
Wireless RF remote control with 7 quick color buttons. The advantage of the RF remote vs IR (infra red) others use is that the remote can be pointed in any direction to work. The IR style needs to be directly pointed at the whip in order to operate the whip. The controllers area built into the whip and only a power/ground wire is needed to run to the whip.
Each whip has 20 different colors and 19 different modes. The modes can be slowed down and sped up via the remote control. There is also brightness controls on the whips. All the remotes are on the same frequency and one remote can operate 2 whips at the same time.
BLUETOOTH WHIPS
These whips do not work off of a remote but rather an app. The controller is built into the whip and does not need any special wiring. However, these whips DO NOT chase, cascade, rainbow, or have any animation to them. The free app has the following functions: App to download Magic Light
  • Colors are changed via the color wheel and thousands of colors area possible.
  • The Function mode is always set to flash in the pre-selected patterns section.
  • Custom mode allows the user to make their own mode and flash patterns for the whips.
  • Music mode allows the whips to flash with the music playing. (This works even when the whips are paired to a Bluetooth stereo system.)
  • Disco Mode allows the whips to change when the sound is picked up thru the phones microphone.
  • Photo mode allows the user to take a photograph of an object and change the whips to that objects color.
  • Group mode allows the user to link up to other 5150 Whips controllers and control all the whips in the group together.
Having a group mode also allows the whips to run perfectly in sync at all times and prevents others from being able to control your whips via the wireless remote.
