Bobalos
- 5,258
I got tired of hauling a whole mess of fuel jugs & am WAY to cheap to buy one of those nice tool boxes with a tank built into them so I got crafty. I found this 50 Gallon Saddle tank on Craigslist/offer up for $75 or $100. They even offered to deliver it to me for another $15, because they had a delivery in the same general area as my office.
I pulled the pickup out of it & modified it with a screen to keep chunks out. I found the pump online & bought the hose on McMaster-Carr. I ran wires from a "fuse panel" that I had previously mounted under the hood & terminated it with Weather-Pack connector on the frame under the truck. Its a shortbed truck so I pull it out when Dune season is over. I have 2 regrets. first is that I pulled the fuel level sender off of the sending unit when I modified it for the pickup I built & second is that I did not get the fuel pump with the filter.
I made the cover out of an old sheet, to keep the sun off of it & the prying eyes off. I dont take it off. I simply flip the switch straight through it and as you can see the hose comes through a hole I cut into it.
It works bitchen & was pretty cheap all options considered.
