Air compressor
matt86m
Need something at the house for car/truck/moho tires. Not running air tools. Doesn't have to be huge but can't use a small pancake.
Moho tires are 110psi
Im in Orange County
You have a compressor built into your RV for filling RV tires. It'll go to 120psi. Now you can get a $100 pancake for your garage.
Look at Dewalt pancake at Home Depot  I think it goes to 140 psi
works fine on my motorhome tires
pretty small
I bought a big (oil-free) California air compressor and it's the most quiet AC I've ever used.  And powerful AF.
The 8 and 10 gallon Harbor freight compressors are pretty good. They are oil but it's nothing to be afraid of and will out lass oil free and they go to 125psi. I have had an 8 gallon for well over 5 years. Whatever you get it will be made in China.
Like LRS said The moho has one for the brakes and air bags. There should be an air chuck at the front. It's there should the rig need to be towed.
there are normally three air tanks in a truck system   1st one is the wet tank where any water and oil wind up the other two tank are fed off that the other two tanks run the service side and the emergency side of your brakes.   i would just put a quickconnect on the wet tank but don't connect to the bottom of the tank. a lot of truck put a shrader valve connection on the air dryer you can replace that with a quickconnect also
Go get yourself a 20 lb CO2 tank - only 20 bucks to refill - its SILENT! haha
I have a 15 in the enclosed (nitrogen) and a 10lb (co2)  in the Jeep but still need a compressor
I have a Harbor Freight Fortress 2 gallon for exactly the same purpose and it is great. Gets to 135 psi quickly, is super quiet, and small and light enough to easily move around. I also take it to the dunes in my trailer.
Ordered the Dewalt but Amazon canceled the order for some reason.
How is Craftsmen now a days? 6 gallon for $130. I can pick it up locally.
I have an older Campbell Hausfield (20 gallon tank) you can have free! Just gotta pick it up in Poway.
Thank you but a little too big. Trying to keep it under the work bench. I appreciate the offer!
Ridgid, Porter Cable, Craftsmen, Bosch,,,,is it all the same crap? I assume in the price range I'm looking for they all would be about the same?
