Jammer75
- 505
Question:
What is the difference between using a hitch receiver tow eye vs tow hook? Why should I chose one over the other? Thank you
asked by: Frank
Expert Reply:
The Tow Eye, like # TR63045, and Trailer Hitch Receiver Mounted Forged Tow Hook, # TR63044 are both used a lot in vehicle recovery and winching operation applications but are not the safest option for other towing needs. The choice between using a tow hook or a tow eye will mostly depend on what exactly you need to recover the vehicle.
If off-road and you get stuck, you could use a winch and pulley block and connect it to a tow eye so it cannot slip off. But if you were pulling a vehicle that got stuck in a ditch or mud, you could use a hook to quickly slip on a tow strap. To determine which one you would need or if there is another option, it really depends on the situation.
expert reply by: Michael H
From the pic's posted it looks to be a drop hitch which put a lot of leverage on the hitch and the inserted tube which IMHO could have contributed to the failure, a straight hitch would have been better and a pintel and a 1 inch screw pin shale would be even better, the straiter the load the more capacity it will have.
I was just going to say the same thing. I've seen straps, hitches and lots of other hardware brake during recoveries and heavy parts sometimes go flying. Fortunately I've never seen anyone get injured from them but there have been times when they hit things like windows and tailgates and stuff. Every time a recovery blanket would have slowed or stopped those parts from flying. I now always insist on putting something weighted on the recovery strap, chain, rope. Nobody including myself carries a recovery blanket but a jacket with a few rocks in the pockets or a chain or whatever. Sometimes people will say "ah, nothin's gonna happen" but if you ask them if they want that shackle going through their grill and radiator or their back window then oddly that seems to be more convincing than personal injury. Go figureWere they really trying to pull out that F250 buried in the mud up to the door jambs using the ball on the end of that giant drop hitch? A Kenworth wrecker would have had a hard time with that. I wonder if a blanket or something heavy thrown over the middle of the tow strap to help deflect the energy if it let go would have helped??
Yes a sad story indeed. My heart goes out to his family.
One of my drop hitches is aluminum. But it is solid aluminum and looks beefy.The hitch almost looks like aluminum with as porous as the metal looks.
Kinda crazy, the way things fail. Makes me wonder about the life of that hitch.
